Config from query transformation
  • 11.6.1
    Add a dynamic threshold via Transformations
    I’ve added a Zabbix query, and added a “Config from query” transformation, to add a threshold based on the last* value
  • What happened?
    The threshold is added, but the original query results are still shown and are drawn over the threshold
    I expect only the threshold to be shown, and the results of the query to be hidden.
    No
    Transform data | Grafana documentation
    and the demo dashboard as reference:
    Grafana
follow this doc for hint…i used this config from query transformation in this post.
