Grafana/Zabbix integration - Dashboard
Hello Everyone,
I would like to set a fixed Threshold value for each one of the “Hosts”. Is there a way to do so?
Grafana integration with Zabbix.
Grafana v7.1.5
Welcome @asanfilippo to the Grafana forum.
In Grafana 8.1 the transformation “Config from query results” was created and designed to solve the underlying use case of dynamic thresholds:
Config from query results:
Docs: Transform data | Grafana documentation
Demo: Grafana
This allows you to use a normal panel query as a source of configuration for unit and thresholds that will be applied to another queries
Hello @grant2 thank you for ypur support.
We upgraded Grafana and tried your suggestion but we found no options when configuring the transformation:
Also, we don’t need dynamic thresholds, we would like static different values for each of the 9 hosts we are monitoring.
Ex:
the first host need the panel “License” with configured threshold 5000
the second one need the panel with threshold 30000
and so on
Thank you again for your help
Hi @asanfilippo
Thanks for explaining further.
The only thing I can think you can do is NOT use a variable for Host and instead create 9 separarate queries for the 9 separate hosts (where the Host name is hardcoded into each of the 9 queries, and each one has its own defined threshold).
