play.grafana.org (Grafana v10.4.0-65039 (da894994d4))
Building a stat panel with min/max and 2 thresholds from a query using the config query transformation (with the pre-configured base threshold color). I made the demo below using the gauge panel since it better displays the min/max and threshold values - and I believe the issue is the same for both.
See this demo dashboard
Using the “Config from query” transformation built into grafana
What happened?
I’m not exactly sure.
That the “Demo: config from query” looked the same as the “Demo: static config from UI” panel
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"type": "grafana",
"uid": "-- Grafana --"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"type": "dashboard"
"description": "Demo: config from query should be identical to Demo: static config from UI",
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": 2688,
"links": [],
"liveNow": false,
"panels": [
"datasource": {
"type": "grafana-testdata-datasource",
"uid": "9cY0WtPMz"
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"mappings": [],
"max": 10,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "red",
"value": null
"color": "green",
"value": 4
"color": "orange",
"value": 6
"unitScale": true
"overrides": []
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 0
"id": 1,
"options": {
"minVizHeight": 75,
"minVizWidth": 75,
"orientation": "auto",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"showThresholdLabels": false,
"showThresholdMarkers": true,
"sizing": "auto"
"pluginVersion": "10.4.0-65039",
"targets": [
"alias": "",
"csvContent": "min,max,threshold_lower,threshold_upper\n0,10,4,6",
"datasource": {
"uid": "9cY0WtPMz"
"hide": true,
"refId": "config",
"scenarioId": "csv_content"
"csvContent": "value\n1",
"datasource": {
"uid": "9cY0WtPMz"
"refId": "B",
"title": "Demo: static config from UI",
"transformations": [],
"type": "gauge"
"datasource": {
"uid": "9cY0WtPMz"
"description": "Broken min/max/thresholds",
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"max": 1,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "red",
"value": null
"color": "green",
"value": 0
"color": "orange",
"value": 1
"unitScale": true
"overrides": []
"gridPos": {
"h": 8,
"w": 12,
"x": 12,
"y": 0
"id": 2,
"options": {
"minVizHeight": 75,
"minVizWidth": 75,
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"sizing": "auto"
"targets": [
"alias": "",
"datasource": {
"uid": "9cY0WtPMz"
"hide": false,
"refId": "config",
"datasource": {
"uid": "9cY0WtPMz"
"refId": "B",
"title": "Demo: config from query",
"id": "configFromData",
"options": {
"applyTo": {
"id": "byFrameRefID",
"options": "B"
"configRefId": "config",
"mappings": [
"fieldName": "threshold_lower",
"handlerKey": "threshold1"
"fieldName": "threshold_upper",
"type": "gauge"
"refresh": "",
"schemaVersion": 39,
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-6h",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "Demo: config from query not always working",
"uid": "a109d4bb-f21d-48b0-ac67-5d171916ca84",
"version": 1,
"weekStart": ""
Not that I have found.
I adapted this example from torkelo
