Selecting data to show using checkbox on Dashbox
    Latest Grafana 8.1.0 for Linux
    Create checkbox for user to select graph to display and compare.
    No idea
  • What happened?
    After clicking the checkbox the data will tabulate on the graph and able to compare.
    Example comparing the power consumption by 2 or more measuring points/database
Cool idea. You should consider starting a formal discussion about this feature enhancement over in the repo :+1:
