Hi all,
I am graphing the readings of a bunch of sensors, with one line per sensor on the graph.
Is there any way, built-in or plug-in, to have some sort of checkbox list that will control which sensors appear on the graph, or not ?
Thanks for the support
Use variable and set mutiple-value and/or include All options
In addition to Fadjar340 answer, you can use the option repeat of a ‘row’ panel for example.
Indeed, that’s what variables are for! Here’s a link to the Repeat panels or rows instructions, but I recommend reading through the Templates and variables section.
