—[Enterprise (Free & unlicensed)]
—[v9.3.2 (21c1d14e91)]
—OS - Running as Docker Image in Ubuntu VM -
– I want to Checkbox to be visualised , Not able to See checkbox when using multi select in grafana variables -
Grafana Variables>> Enabling the Multi Select for the Variable
What happened?
–Not able to See checkbox when using multi select in grafana variables -
– I want the checkbox to be visible which is currently not visible
