Problems selecting variables (multi-vars) on mobile device
I have some problems when using dashboards on mobile (only had the chance to test on iphone) and want to select values in a multi variable dropdown. When I try to select a value, its not selected, i have to open the dropdown again, select the same variable then it seems to be selected.
I found this github issue explaining exactly the same issue I’m having and in more details with a video as well: Dashboards: unpredictable behavior with select variables on mobile · Issue #98419 · grafana/grafana · GitHub but with no activity sadly.
I still have this issue on v11.6.1.
Anyone else having issues with this on mobile?
Same problem on Android and Grafana v12.0.0
Very little activity on the github issue unfortunately. Dashboards with multi var selection on mobile is very hard to use / almost useless :confused:
