The Current Grafana version that i am using is Grafana v11.5.0
In the table panel I should be able to select the values inside the table using a checkbox and update the values that i have selected
Currently I am using the variable name and values in the dashboard to select the values in the table.
If there are 100+ values for that variable then selecting the values in the variable dropdown will not look good.
A checkbox option to select multiple values within the table itself.
Is there any workaround for this option?
@amaljoseph109 Hi, have you got solution how to make it work?
One way to do it is using business variable
@yosiasz sorry, I should have made clear.
Is there a way where for a table in each row the first column is a check box and we can select multiple values(rows) in table and click on submit button for backend processing
