Table filter select multi value
  • What Grafana version and what operating system are you using? I’m using Grafan 8.3.2
  • What are you trying to achieve? I setup a dashbaord with table view and filter enable
    The table contains lot of lines and the user would like to use filter to find informations but in many case, the criteria is too large and the user need to select 10 or more value on the filter, then maybe an option to “check all” would be appreciate.
  • How are you trying to achieve it? On table plugin, filter enable
  • What happened? there is no issue just a new function on usage experience
  • What did you expect to happen? I expect to have a choice to get ‘all filter’ result checked
  • Can you copy/paste the configuration(s) that you are having problems with? N/A
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No error
    I search if the solution exists
