bpk
March 27, 2018, 7:37am
1
I have already created a Table panel by adding all the Column names. Now I have created a Templating (Filter).
Eg: My templating is “Country”.
Whenever I select the values in templating, my table is not Filtered by the Templating values. Kindly help me.
We’ll need more information. Please provide
Your Grafana version
The name of data source that you’re using
Query you’re using for your table
Thanks
Marcus
bpk
March 27, 2018, 8:11am
3
Grafana 5.0
Data source: Elastic Search
I haven’t return Query. I have selected Raw Document, and in the “Options” tab, I am adding all the columns required to display.
Template: I have Country Template. {“find”: “terms”, “field”: “Country.keyword”}
Okay. But in order for the table to be filtered you need to actually add the template variable filter to your table query.
Marcus
bpk
March 28, 2018, 5:48am
5
Thanks, I have created and got the answer.
I gave this in Table Query. Its working.
Country.keyword:$Country AND Center.keyword:$Center
