Grafana Version 6.7.4
Windows 10 Operating System -
I have filters/variables at the top of my dashboard which applies to all the panels. I want to filter the columns from one of the panel of type table based on the selected filter.
For example - I have variable Country with Values ALL, US, UK, IRE, AUS.
My Table panel has columns as - ID, US, UK, IRE, AUS
If I select ALL then table should display data for all columns (ID, US, UK, IRE, AUS)
If I select UK then the list of columns should be (ID, UK)
If I select US, UK then the list of columns should be (ID, US, UK)
So, the variable should drive the table format.
Number of rows will be the same for all the columns. -
I have no clue. -
What happened?
welcome to the
forum, @rengeraunak
It sounds like you want to use chained variables. Here are some useful starting points and example dashboards in our public sandbox ![]()
