Hi All,
I’m trying to create a table in Grafana (v6.7.4) with a multiple rows selection and, by pressing a button in another panel (called HTML) print out all the selected rows values separated by semicolon.
for example selecting the first 3 rows, then pressing the Execute button, i want to show the following:
10|2021-02-08T09:34:22Z|2021-02-08T11:52:20Z;4|2021-02-05T21:27:11Z|2021-02-08T09:33:10Z;1|2021-02-05T15:57:56Z|2021-02-05T21:26:33Z
i know that it can be possible to create a clckable cell for each row through the flag ‘Render value as link’ in the visualization option of the panel (inside Column Styles).
I can also get the value of each cell of the clicked row inside the Link-url using: ${__cell_1}|${__cell_2}|${__cell_3} and refresh the same Dashboard with the new information in the url. But i can get only one info at a time and i can’t select/unselect the rows.
this approach has the side effect that rows are unselectable, so i’m asking you guys how can i solve this problem, maybe there is a plugin that is able to do so or there is a workaround using Grafana variables to make a selectable row like a checkbox.
Thanks in advance.
Luca
