Hello all,
I am quite new to Grafana , so please take it easy on me
I am trying to setup an app called SEQ on the same server (Windows Server 2012 R2) where Grafana is installed.
My problem is that SEQ cannot start , and getting this error :
The Seq server could not be started","@l":“Fatal”,"@x":"Microsoft.AspNetCore.Server.HttpSys.HttpSysException (32): The process cannot access the file because it is being used by another process
If I stop Grafana , I can start SEQ without any issues .
My guess is that Grafana is bind to the 443 port instead of grafana.mydomain.com:443 as we want it to be.
Is there a way to set Grafana to respond only to requests sent tografana.mydomain.com:443, instead of responding to all requests on port 443?
The defaults.ini is as below:
[server]
Protocol (http, https, socket)
protocol = https
The ip address to bind to, empty will bind to all interfaces
http_addr =
The http port to use
http_port = 443
The public facing domain name used to access grafana from a browser
domain = mydomain (FQDN name is here)
Redirect to correct domain if host header does not match domain
My problem is that SEQ cannot start, and getting this error :
The Seq server could not be started", “@l”: “Fatal”, “@x”:
Do you know which file is being referred to?
It would be a strange error message to produce if it really means a network
socket.
What makes you think this is a network socket problem rather than a file access
problem?
Is there a way to set Grafana to respond only to requests sent to grafana.mydomain.com:443, instead of responding to all requests on port
443?
Yes, provided you have at least two IP addresses on the server, and grafana.mydomain.com resolves to one of them, then you can use the other one
for SEQ.
[server]
protocol = https
http_addr =
So, set here the IP address which grafana.mydomain.com resolves to, and it
will only bind to that address.
The tell SEQ to bind to the other address, and they won’t conflict (assuming
that that really is your problem).
I think the C:\Windowds\system32\drivers\http.sys file is in use.
The problem is not file access for sure, as SEQ starts without any issues when Grafana is stopped.
I do not have 2 IPs on that machine, and not planning to have them in the future.
So, if we do not have 2 IPs, it shouldn’t be possible to make it work?
Maybe using “netsh http add urlacl” command? Not sure of the impact it will have on Grafana .
Try setting Grafana to use another port than 443. Even if you really need to have it on port 443 later, try setting it to another port to make sure your assertion that the port allocation is the problem is correct.
If you need both to be accessible at port 443 but on different domains you’ll need something like a reverse proxy to set that up. A reverse proxy allows you to expose both Grafana and SEQ on other ports, and the reverse proxy on 443 which will forward traffic to the applications. I’m not a Windows user, but it seems like you can use IIS’s url rewrite for this, otherwise the most popular reverse proxy on the market is nginx or envoy.
From what I understand from other forums related to the error I get, if Grafana or any other app, has exclusive access to port 443, it blocks that file. At least this is how I understand it. Setting services to listen to their own socket would fix it.
In that case you can’t have two things both listening on the same port.
Well, why not make one or the other listen on a different port number?
I wanted to avoid this as there are 2 different firewalls (also providers) to be configured to allow the communication. So it will take some time get it done. In the end this might be the only option.
