Grafana Service Fails When Using Port 443 Https
I’ve set up Grafana using IIS and port forwarding to port 3000 which is the default https port used by Grafana.
Setup as:
Protocol (http, https, h2, socket)
protocol = https
The ip address to bind to, empty will bind to all interfaces
;http_addr =
The http port to use
http_port = 443
The public facing domain name used to access grafana from a browser
domain = domain.com.au
root_url = https://grafana.domain.com.au:3000
I wanted to update this to 443 so users don’t need to type in the port in the URL, however, when defining port 443 in the custom.ini file used, I recieve the below errors in the log:
msg=“Initializing Stream Manager”
t=2020-03-13T13:54:08+1000 lvl=eror msg=“Stopped HTTPServer” logger=server reason=“failed to open listener on address 0.0.0.0:443: listen tcp 0.0.0.0:443: bind: An attempt was made to access a socket in a way forbidden by its access permissions.”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped Stream Manager”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped BackendPluginManager” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-03-13T13:54:08+1000 lvl=eror msg=“A service failed” logger=server err=“failed to open listener on address 0.0.0.0:443: listen tcp 0.0.0.0:443: bind: An attempt was made to access a socket in a way forbidden by its access permissions.”
t=2020-03-13T13:54:08+1000 lvl=eror msg=“Server shutdown” logger=server reason="failed to open listener on address 0.0.0.0:443: listen tcp 0.0.0.0:443: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
Any advice is much appreciated!
Thank you
Steelo
setcap 'cap_net_bind_service=+ep' /usr/sbin/grafana-server
that should solve the issue? or what?
would really appreciate if someone can help with this as i am trying to do the same.
Adding this for people stumbling upon this old post while looking for solution to bind the port 443 to the grafana-server exec file.
Please note the latest Grafana binary (starting Grafana 10.x) was changed to use grafana as executable instead of grafana-server file.
So, you should use:
Also, you should change the grafana-server to grafana server in the ExecStart line in your grafana-server.service file (usual location: /etc/systemd/system/grafana-server.service )
