Remove port in URL?
Is it possible to remove the port in the URL for grafana?
I configured our server to use a custom SSL cert and wanted the URL to display as https://graphs.domain.com but I have to put in https://graphs.domain.com:3000 (or whatever port)
My grafana.ini is below:
#################################### Server ####################################
[server]
Protocol (http or https)
protocol = https
The ip address to bind to, empty will bind to all interfaces
http_addr = 10.10.10.10
The http port to use
;http_port = 3000
The public facing domain name used to access grafana from a browser
domain = https://graphs.domain.com
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
;enforce_domain = false
The full public facing url you use in browser, used for redirects and emails
If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://graphs.domain.com
Log web requests
;router_logging = false
the path relative working path
;static_root_path = public
enable gzip
;enable_gzip = false
https certs & key file
cert_file = /etc/grafana/grafana.pem
cert_key = /etc/grafana/grafanakey.pem
I had the port specified to 443 but it would not restart the service, kept erroring out
EDIT: Sorry…this was my mistake…forgot about some firewall-cmd rules that were in place. All is good now
Please use a reverse proxy like nginx, haproxy or apache, see documentation.
I have the same issue using a reverse proxy, domain is configured to whatever.com but grafana still appends the http_port to URLs…
Regards
Please configure the root_url to your public facing url, i.e. http://whatever.com.
Hi
Thanks a lot, this seems to do it. However, maybe the doc could be slightly improved because root_url definition is quite unclear.
Regards
Feel free to open a PR with your suggested changes.
I find it quite clear, but I may be biased http://docs.grafana.org/installation/configuration/#root-url
