i have running Grafana and Kibana for other purposes on the same server. I have configured an apache2. The certificates are from letsencnrypt. I dont get grafana in https running and i dont know why. Thats my settings:
#################################### Server ####################################
[server]
Protocol (http, https, socket)
protocol = https
The ip address to bind to, empty will bind to all interfaces
;http_addr =
The http port to use
http_port = 3000
The public facing domain name used to access grafana from a browser
domain = apm.domain.de
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
;enforce_domain = false
The full public facing url you use in browser, used for redirects and emails
If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://apm.domain.de:3000
Log web requests
;router_logging = false
the path relative working path
;static_root_path = public
enable gzip
;enable_gzip = false
https certs & key file
cert_file =/etc/letsencrypt/live/apm.domain.de/cert.pem
cert_key =/etc/letsencrypt/live/apm.domain.de/privkey.pem
Unix socket path
;socket =
Thats the Apache config:
<VirtualHost *:443>
ServerAdmin webmaster@localhost
ServerName apm.domain.de
ServerAlias apm1.domain.de
DocumentRoot /var/www/html
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
ProxyRequests Off
ProxyPreserveHost On
RequestHeader set X-Forwarded-Proto https
RequestHeader set X-Forwarded-Port 443
<Proxy *>
Require all granted
</Proxy>
ProxyPass / https://apm.domain.de:3000/
ProxyPassReverse / https://apm.domain.de:3000/
SSLEngine on
SSLCertificateKeyFile /etc/letsencrypt/live/apm.domain.de/privkey.pem
SSLCertificateFile /etc/letsencrypt/live/apm.domain.de/fullchain.pem
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
</VirtualHost>
