I am using apache and grafana to deliver some pretty slick graphs! I am having some issues though redirecting non-ssl traffic to https. Right now, https traffic works fine as long as I go to the https://servername:3000 address. Usually this wouldn’t be too complicated as you would just redirect port 80 to 443 via iptables/firewall-cmd but it seems that grafana is only capable of listening on one port at a time. Would be nice to be able to combine http/https in one config file! Alas…
So, any tips on how to do this? My httpd.conf file is 100% default as it comes from a fresh yum install httpd. This is my grafana.ini (with the domain redacted):
[root@rzslcreport1 grafana]# grep -v ^# ./grafana.ini | grep -v ^; | grep -v “^[” | grep .
protocol = https
http_port = 3000
domain = example.org
root_url = %(protocol)s://%(domain)s:%(http_port)s/
cert_file = /etc/grafana/certificate.pem
cert_key = /etc/grafana/key.pem
enabled = true
config_file = /etc/grafana/ldap.toml
allow_sign_up = true
Any help is greatly appreciated.
