cat
1
I’m a beginner of Grafana and trying to create an URL redirection from server.domain.com:3000/login to server.domain.com/grafana in Apache.
I’m unable to open the Grafana login page. The port was changed from 3000 to 80 in grafana.ini.
Here is the Apache config file. Did I do something wrong?
<VirtualHost *:80>
DocumentRoot /usr/share/grafana/
ServerName server.domain.com
RewriteEngine on
RewriteRule ^/?$ /grafana [R=permanent,L]
<Directory "/usr/share/grafana/">
Require all granted
AllowOverride All
Options FollowSymLinks MultiViews
</Directory>
</VirtualHost>
dcech
2
Not sure what you’re trying to do here, it sounds like you want to use Apache listening on port 80 as a reverse proxy.
<VirtualHost *:80>
RewriteEngine on
RewriteRule ^/?$ /grafana/ [R=permanent,L]
<Location "/grafana">
ProxyPass http://grafana.staged-by-discourse.com
</Location>
ProxyPassReverse /grafana http://grafana.staged-by-discourse.com
</VirtualHost>
Then in your grafana custom.ini:
[server]
http_addr = 127.0.0.1
http_port = 3000
root_url = http://server.domain.com/grafana/
That will set Grafana up to listen on port 3000 on localhost, and Apache to listen on port 80, requests to http://server.domain.com/grafana/ will get reverse proxied to Grafana, and requests to http://server.domain.com/ will get redirected to http://server.domain.com/grafana/
