[Resolve] Grafana ApacheHTTP url
I have an issue with the configuration of ApacheHttp with grafana. Actually Grafana is install on a Windows server and we aces it by the url : http://[serverName]:[GrafanaPort].
I have install a Apache server in order to change the grafana url to http://[serveurName]/grafana.
actually I put this in the httpd-vhosts.conf of the apache :
ProxyPreserveHost On
ProxyRequests On
ServerName http://[serverName]
ServerAlias [serverName]
ProxyPass /grafana http://localhost:[GrafanaPort]/login
ProxyPassReverse /grafana http://localhost:[GrafanaPort]/login
and when I try to reach the url http://[serveurName]/grafana those requests fail, and lead my to these screen:
GET http://[serverName]/public/css/fonts.min.css [HTTP/1.1 404 Not Found 10 ms]
GET http://[serverName]/public/css/grafana.dark.min.css [HTTP/1.1 404 Not Found 14 ms]
GET http://[serverName]/public/app/boot.js [HTTP/1.1 404 Not Found 24 ms]
GET http://[serverName]/public/app/boot.js [HTTP/1.1 404 Not Found 7 ms]
those requests don’t fail when I use the url http://[serverName]:[GrafanaPort]
GET http://[serverName]:[grafanaPort]/public/css/fonts.min.css [HTTP/1.1 304 Not Modified 3 ms]
GET http://[serverName]:[grafanaPort]/public/css/grafana.dark.min.css [HTTP/1.1 304 Not Modified 5 ms]
GET http://[serverName]:[grafanaPort]/public/app/boot.js [HTTP/1.1 304 Not Modified 6 ms]
GET http://[serverName]:[grafanaPort]/public/img/grafana_icon.svg [HTTP/1.1 304 Not Modified 3 ms]
Did some one know how to correctly configure Apache to allow the url http://[serveurName]/grafana to work?
What does your Grafana config look like?
Initialy I had only the http_port which was define, this morning I did a test with this:
http_port = [GrafanaPort]
domain = [serveurName]
root_url = http://localhost/grafana
but I succeed nothing.
Is this url correct? Should it not be http://grafana.staged-by-discourse.com/grafana ? (where 3000 is your GrafanaPort).
you are right, it works. So this is the final configuration:
for apache: httpd-vhosts.conf
<VirtualHost *:80> ProxyPreserveHost On ProxyRequests On ServerName http://[serveurName] ServerAlias [serveurName] ProxyPass /grafana http://localhost:[GrafanaPort] ProxyPassReverse /grafana http://localhost:[GrafanaPort] </VirtualHost>
for grafana: custom.ini
[server]
root_url = http://localhost:[GrafanaPort]/grafana
Thank :slight_smile:
