Grafana (9.0.7) on Windows Server 2012 hosted on Azure -
I want to add the custom domain and want to redirect from community.grafana.com -
We have installed apache2 and Grafana on the server. -
What happened?
Basically there are other 4 atlassian tools are hosted on the same server. community.grafana.com is not redirecting to mygrafanadomain.com. Also, while opening mygrafanadomain.com is opening atlassian tool. We checked each and every line in apache 2 and there is nothing which redirect it to atlassian tool. -
whenever http://grafana.staged-by-discourse.com or http://mygrafanadomain.com is clicked then it should redirect to Grafana url along with https (it means the url should be https://mygrafanadomain.com) -
Grafana defaults.ini File
#################################### Server ##############################
[server]
#Protocol (http, https, h2, socket)
protocol = http
#protocol = https
I tried both http and https with no success.
#The ip address to bind to, empty will bind to all interfaces
#http_addr = 127.0.0.1
http_addr = localhost
I tried both no success.
#The http port to use
http_port = 3000
#http_port = 3000
#The public facing domain name used to access grafana from a browser
#domain = localhost
domain = mygrafanadomain.com
#Redirect to correct domain if host header does not match domain
#Prevents DNS rebinding attacks
;enforce_domain = false
#The full public facing url
#root_url = %(protocol)s://%(domain)s:%(http_port)s/
root_url = https://mygrafanadomain.com/
#Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
#serve_from_sub_path = false
#Log web requests
router_logging = false
#the path relative working path
static_root_path = public
<VirtualHost mygrafanadomain.com:443>
ServerName mygrafanadomain.com
ErrorLog "${SRVROOT}/logs/error_grafana.log"
TransferLog "${SRVROOT}/logs/access_grafana.log"
ProxyRequests Off
ProxyPreserveHost On
<Proxy *>
Require all granted
</Proxy>
SSLEngine On
ProxyTimeout 300
SSLCertificateFile /DATA/Apache24/certificates/SSLCERT.crt
SSLCertificateKeyFile /DATA/Apache24/certificates/SSLCERT.key
SSLCertificateChainFile /DATA/Apache24/certificates/SSLCERT-ca.crt
ProxyPass / https://community.grafana.com/
ProxyPassReverse / https://community.grafana.com/
</VirtualHost>
No Error in the logs -
https://www.turbogeek.co.uk/grafana-how-to-configure-ssl-https-in-grafana/
Run Grafana behind a reverse proxy | Grafana Labs
Grafana as virtual host with apache https redirect and not default port
Thanks in advance
SultanPr
