I am attempting to move my Grafana install from a non-SSL to SSL link. It sits behind an Apache reverse proxy and worked fine before I tried to set up SSL.
I have seen many tutorials that look like this one, which is what I have done.
My Apache config looks like this (with the domain name changed to example.com)
ServerAdmin nermel@example.com
ServerName grafana.example.com
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{SERVER_NAME}$1 [R,L]
ErrorLog /var/log/apache2/grafana.example.com-error_log
CustomLog /var/log/apache2/grafana.example.com-access_log common
</VirtualHost>
<VirtualHost *:443>
ServerSignature Off
SSLEngine on
SSLCertificateFile /opt/repos/dehydrated/certs/grafana.example.com/cert.pem
SSLCertificateKeyFile /opt/repos/dehydrated/certs/grafana.example.com/privkey.pem
SSLCertificateChainFile /opt/repos/dehydrated/certs/grafana.example.com/chain.pem
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
ProxyPreserveHost On
ProxyPass / http://0.0.0.0:3000/
ProxyPassReverse / http://0.0.0.0:3000/
</VirtualHost>
In my grafana.ini I’ve only changed the following. Everything else is still commented out and using defaults:
domain = grafana.example.com
root_url = https://grafana.example.com
I have no errors in my grafana.log file and it starts up as expected. It ends with
t=2019-05-30T14:51:31-0500 lvl=info msg="HTTP Server Listen" logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
My DNS entries and SSL certificates are correctly installed.
If I visit the full URL (grafana.example.com) Apache performs a ton of redirects and then the request fails with Chrome reporting that to many redirects have occurred. My access log looks like this (with the IPs scrubbed)
162.158.xxx.xxx - - [30/May/2019:14:51:57 -0500] "GET /?orgId=1 HTTP/1.1" 302 581
162.158.xxx.xxx - - [30/May/2019:14:51:58 -0500] "GET /?orgId=1 HTTP/1.1" 302 580
162.158.xxx.xxx - - [30/May/2019:14:51:58 -0500] "GET /?orgId=1 HTTP/1.1" 302 581
162.158.xxx.xxx - - [30/May/2019:14:51:59 -0500] "GET /?orgId=1 HTTP/1.1" 302 580
There are no errors in my apache error log.
Prior to trying to move to SSL, my virtual host looked like this and worked as expected:
<VirtualHost *:80>
</VirtualHost>
What do I need to do so that I can use Apache as a reverse proxy and use SSL to connect to Grafana?
