Grafana not accessible over https
My grafana running on a linux machine has the following configuration. But grafana is not loading.
Protocol (http, https, socket)
protocol = https
The ip address to bind to, empty will bind to all interfaces
http_addr = xx.xx.xx.xx
The http port to use
http_port = 443
The public facing domain name used to access grafana from a browser
domain = ec2-xx-xx-xx-xx.compute-1.amazonaws.com
https certs & key file
cert_file = /local/ams-grafana.crt
cert_key = /local/ams-grafana.key
When am starting the Grafana, am getting below error.
t=2019-08-08T17:58:51+0000 lvl=info msg=“HTTP Server Listen” logger=http.server address=xx.xx.xx.xx:443 protocol=https subUrl= socket=
t=2019-08-08T17:58:51+0000 lvl=eror msg=“Stopped HTTPServer” logger=server reason=“listen tcp xx.xx.xx.xx:443: bind: cannot assign requested address”
t=2019-08-08T17:58:51+0000 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
Grafana running as root user.
Can anybody help?
Hi techies,
It is possible that the error is that you are trying to bind the public ip. This ip cannot be bind by an instance of ec2, instead you must bind the ip of the vpc or all the ip with 0.0.0.0
