What Grafana version and what operating system are you using? V 11.2.0 on Windows 10 (current).
What are you trying to achieve? see below
How are you trying to achieve it? see below
What happened?
I have a dashboard with 8 time series panels on it. One of the panels has started to behave oddly.
1, On all the panels except the rogue I can left click and select a time span of interest and when I release the button the display of all panels will zoom to that time span. On the rogue panel I can left click and drag and a span is highlighted but when I release the button the highlight disappears and none of the panels zoom.
- If I move he mouse over a data area of any of the panels a time corresponding dot shows up on all the other panels except the rogue, and if I move the cursor over the rogue I see a vertical line but no dot and also no dot on any other panel.
This is a fairly recent development but I cannot relate the change to any specific update or event.
- Can you copy/paste the configuration(s) that you are having problems with?
Here is the json of the rogue panel:
“datasource”: {
“type”: “influxdb”,
“uid”: “s6dWfU27k”
“fieldConfig”: {
“defaults”: {
“custom”: {
“drawStyle”: “bars”,
“lineInterpolation”: “linear”,
“barAlignment”: 1,
“barWidthFactor”: 0.6,
“lineWidth”: 1,
“fillOpacity”: 0,
“gradientMode”: “none”,
“spanNulls”: false,
“insertNulls”: false,
“showPoints”: “auto”,
“pointSize”: 1,
“stacking”: {
“mode”: “none”,
“group”: “A”
“axisPlacement”: “auto”,
“axisLabel”: “”,
“axisColorMode”: “text”,
“axisBorderShow”: false,
“scaleDistribution”: {
“type”: “linear”
“axisCenteredZero”: false,
“hideFrom”: {
“tooltip”: false,
“viz”: false,
“legend”: false
“thresholdsStyle”: {
“mode”: “off”
“color”: {
“mode”: “fixed”,
“fixedColor”: “dark-blue”
“mappings”: ,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “red”,
“value”: 80
“overrides”:
“gridPos”: {
“h”: 4,
“w”: 24,
“x”: 0,
“y”: 0
“id”: 2,
“options”: {
“tooltip”: {
“mode”: “none”,
“sort”: “none”
“legend”: {
“showLegend”: true,
“displayMode”: “list”,
“placement”: “bottom”,
“calcs”: [
“sum”
“targets”: [
“groupBy”: ,
“measurement”: “pulses/min”,
“orderByTime”: “ASC”,
“policy”: “default”,
“refId”: “A”,
“resultFormat”: “time_series”,
“select”: [
“params”: [
“value”
“type”: “field”
“tags”:
“title”: “Water Consumption”,
“type”: “timeseries”
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No errors in the UI or log
Did you follow any online instructions? If so, what is the URL? No
