I am a beginner in using grafana, I see that there is no similarity between the data between grafana and the postgreeSql source data, you can see the results of the simple query that I did below
and this simple query in postgreesql
i hope data in grafana match with postgreesql, can you help me about that
It will be nice if you say what’s a difference, so viewers don’t need to spend time to search difference.
For the record - timestamps are different.
Timstamps are different, because Grafana uses timezone in your browser. It assumes that timestamps in DB are saved in the UTC, so it “moves” them to local browser timezone for user convenience. If you really want the same timestamps, then set your dashboard timezone to UTC.
