[SYSTEM]
- Grafana versoin: v8.1.3
- OS: Red Hat Enterprise Linux
- MySQL version: v8.0.34
Hello:)
I’m creating the dashboard with MySQL Data source. The time data performed the query directly in the database is different from the data performed the query in the grafana dashboard.
This is the time data from database.
This is the time data from grafana.
** The timing of data is the same. But I got the different data. Even though today is August 16th.
- This is the query i made.
select
a.hostname as “Hostname”
,a.timedate as “Time”
,a.cpu_sys as “System or Privilegedtime”
,b.cpu_user as “User or Usertime”
,c.cpu_iowait as “Iowait or Processortime”
,d.cpu_idle as “Idle or Interrupttime”
FROM
SELECT
h.host as hostname
,STR_TO_DATE(truncate(DATE_FORMAT(FROM_UNIXTIME(hi.clock),‘%Y%m%d%H%i%S’),-3),‘%Y%m%d%H%i%S’) as timedate
,MAX(hi.value) as cpu_sys
from items i , hosts h , history hi
where 1=1
and i.hostid=h.hostid
and i.itemid = hi.itemid
and hi.clock >= 1692167206 AND hi.clock <= 1692170806 ##Time range 변수
and i.name in (
##평균을 내고싶은 종목 명
‘CPU system 10m’
and h.host in (‘kbamstarf02’) ## 시스템 명
GROUP BY
h.host,
) a,
SELECT
h.host as hostname
,MAX(hi.value) as cpu_user
where 1=1
and i.name in (
##평균을 내고싶은 종목 명
‘CPU user 10m’
GROUP BY
h.host,
) b ,
SELECT
h.host as hostname
,MAX(hi.value) as cpu_iowait
where 1=1
and i.name in (
##평균을 내고싶은 종목 명
‘CPU iowait 10m’
GROUP BY
h.host,
) c,
SELECT
h.host as hostname
,MAX(hi.value) as cpu_idle
where 1=1
and i.name in (
##평균을 내고싶은 종목 명
‘CPU idle 10m’
GROUP BY
h.host,
) d
where 1=1
and a.hostname = b.hostname
and a.hostname = c.hostname
and a.hostname = d.hostname
and a.timedate = b.timedate
and a.timedate = c.timedate
and a.timedate = d.timedate
It doesn’t seem to be a query problem. Because I can get the data well when I performed a query directly from the database.
Does anyone know what’s wrong?
I’d really appreciate it if you could answer.
