Dear All,
Presently i am using Time Series graph
Following are the SQL-Table Output
When i use the same query in Grafana, Graph is displaying but time in the SQL and Grafana is not matching.
Present system time is 8:57 AM
Any suggestion please…
Dear All,
I do not know if this helps, but apparantly the MySQL server is running in another timezone as your Grafana instance. This can happen if, for example, you are using a MariaDB instance on your NAS.
