Reseted router. I can not open my grafana dashboard
    I do not know. I only know that before I wrote a local ip in the web browser and the dashboard appeared.
    I want the dashboard to appear.
  • What happened?
    Yesterday, I rebooted the router of the company where I work. I reconfigured the same ip on the computer (server) where Grafana was installed. Everything is the same. I have internet access. I have a web server (XAMPP) and a web application that are running. But, the Grafana dashboard does not appear when I enter the local IP address from where we accessed everything before.
    someone help me
    the ip that I typed in my local computers was 192.168.2.11:3000. And the page loaded and showed me the login panel. I would type my credentials and the Grafana dashboard would appear. Now I only get error 523.
    No.
    None.
On which maschine does your Grafana Instance run?
