New user to Grafana here and have just setup v8.0.2 on a local server to pull information from PRTG, Azure and a couple other places. When accessing the grafana service through community.grafana.com I can login and the dashboards work correctly, everything I have created displays data.
However when trying to access remotely with the IP address:3000 I can login to and see the UI fine however the panels are all empty, some have error undefined:undefined. I have others which are just sourcing web pages through iframe and they display error 404. The same if I share a link to the dashboard or snapshot.
Is there anything else I need to setup in order for the dashboards to display data when accessing through the IP address?
Any advice appreciated, thanks.
