I setup a docker container running Grafana v7.2.1.
To include some data I used provisioning (as described in the doc) to populate my container with a data source and some dashboards.
To run the container on port 3000 I execute docker run -p 3000:3000 -v $(pwd)/provisioning:/etc/grafana/provisioning gf where provisioning is a local directory containing two yaml config files for my data source and dashboards and json files for the dashboards.
After starting the container I can access Grafana using http://grafana.staged-by-discourse.com. On the landingpage I see all dashboards.
But when I try to access the Grafana using my local IP http://<ip>:3000 I do not see the dashboards. Login and the data source are availalbe though.
Is there any option to show my dashboards?
// edit:
I found the dashboards under Dashbaords -> Manage. So they are there but do not show up in on the landing page.
