I have installed and configured Grafana, but the dashboard is not showing when I go to 127.0.0.1:3000. I get the following
The problem here is that the JavaScript and CSS files have not loaded.
Can you provide some more information:
That mostly happens when you are using a proxy.
Configure it properly in the Grafana.ini file and also in the Web-server conf file.
It is running on Win10 x64 NGINX with reverse proxy set to port 3000 in nginx.conf and grafana config.
t=2017-05-13T00:29:52+1000 lvl=info msg=“Shutdown started” logger=server code=0 reason=“system signal: interrupt”
t=2017-05-13T00:30:33+1000 lvl=info msg=“Starting Grafana” logger=main version=4.2.0 commit=349f3eb93 compiled=2017-03-22T21:06:41+1100
t=2017-05-13T00:30:33+1000 lvl=info msg=“Config loaded from” logger=settings file=D:\nginx\html\grafana/conf/defaults.ini
t=2017-05-13T00:30:33+1000 lvl=info msg=“Config loaded from” logger=settings file=D:\nginx\html\grafana\conf\custom.ini
t=2017-05-13T00:30:33+1000 lvl=info msg=“Path Home” logger=settings path=D:\nginx\html\grafana
t=2017-05-13T00:30:33+1000 lvl=info msg=“Path Data” logger=settings path=D:\nginx\html\grafana\data
t=2017-05-13T00:30:33+1000 lvl=info msg=“Path Logs” logger=settings path=D:\nginx\html\grafana\data\log
t=2017-05-13T00:30:33+1000 lvl=info msg=“Path Plugins” logger=settings path=D:\nginx\html\grafana\data\plugins
t=2017-05-13T00:30:33+1000 lvl=info msg=“Initializing DB” logger=sqlstore dbtype=sqlite3
t=2017-05-13T00:30:33+1000 lvl=info msg=“Starting DB migration” logger=migrator
t=2017-05-13T00:30:34+1000 lvl=info msg=“Executing migration” logger=migrator id=“copy data account to org”
t=2017-05-13T00:30:34+1000 lvl=info msg=“Skipping migration condition not fulfilled” logger=migrator id=“copy data account to org”
t=2017-05-13T00:30:34+1000 lvl=info msg=“Executing migration” logger=migrator id=“copy data account_user to org_user”
t=2017-05-13T00:30:34+1000 lvl=info msg=“Skipping migration condition not fulfilled” logger=migrator id=“copy data account_user to org_user”
t=2017-05-13T00:30:34+1000 lvl=info msg=“Creating json dashboard index for path: [D:\nginx\html\grafana\data]”
t=2017-05-13T00:30:36+1000 lvl=info msg=“Starting plugin search” logger=plugins
t=2017-05-13T00:30:37+1000 lvl=info msg=“Registering plugin” logger=plugins name=Clock
t=2017-05-13T00:30:38+1000 lvl=info msg=“Initializing CleanUpService” logger=cleanup
t=2017-05-13T00:30:38+1000 lvl=info msg=“Initializing Alerting” logger=alerting.engine
t=2017-05-13T00:30:38+1000 lvl=info msg=“Initializing Stream Manager”
t=2017-05-13T00:30:38+1000 lvl=info msg=“Initializing HTTP Server” logger=http.server address=0.0.0.0:3000 protocol=http subUrl=/grafana
t=2017-05-13T00:55:47+1000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/grafana/ status=404 remote_addr=192.168.20.1 time_ms=152ns size=8635
t=2017-05-13T00:55:47+1000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/grafana/public/css/fonts.min.css status=404 remote_addr=192.168.20.1 time_ms=35ns size=8635
t=2017-05-13T00:55:47+1000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/grafana/public/app/boot.js status=404 remote_addr=192.168.20.1 time_ms=33ns size=8635
t=2017-05-13T00:55:47+1000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/grafana/public/css/grafana.dark.min.css status=404 remote_addr=192.168.20.1 time_ms=75ns size=8635
t=2017-05-13T00:55:48+1000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/grafana/public/css/grafana.dark.min.css status=404 remote_addr=192.168.20.1 time_ms=53ns size=8635
t=2017-05-13T00:55:48+1000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/grafana/public/app/boot.js status=404 remote_addr=192.168.20.1 time_ms=28ns size=8635
I ran into the same issue. Sounds like it may be related to https://github.com/grafana/grafana/issues/8089. May be fixed in 4.3.0 Beta1.
Appears to still be broken in 4.3.0-beta1.
Added comment to https://github.com/grafana/grafana/issues/8089
Replied to the issue. I don’t think it is a bug.
Grafana custom.ini
[server]
protocol = http
;http_addr =
http_port = 3000
domain = localhost
;enforce_domain = false
root_url = http://localhost/grafana
;router_logging = false
;static_root_path = public
;enable_gzip = false
;cert_file =
;cert_key =
NGINX nginx.conf
# Grafana HTTP server
server {
listen 80;
server_name grafana.dizzle.me;
if ($scheme = http) { return 301 https://$server_name$request_uri; }
#charset koi8-r;
#access_log logs/host.access.log main;
#error_page 404 /404.html;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root html;
location ~ /.well-known {
allow all;
# setup proxy and sub URL for Grafana
location /grafana {
proxy_pass http://127.0.0.1:3000;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_read_timeout 300;
# Grafana HTTPS server
server {
listen 443 ssl;
ssl_certificate d:/nginx/ssl/dizzle.me-crt.pem;
ssl_certificate_key d:/nginx/ssl/dizzle.me-key.pem;
ssl_trusted_certificate d:/nginx/ssl/dizzle.me-chain.pem;
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
location / {
proxy_set_header X-Forwarded-Proto $scheme;
proxy_read_timeout 90;
proxy_redirect http://127.0.0.1:3000 http://grafana.dizzle.me;
I had the same problem. Tried to install grafana on a kubernetes cluster via https://github.com/kayrus/prometheus-kubernetes/blob/master/grafana-deployment.yaml
(tried it with the 3.1.1, 4.2.0 and 5.1.0)
When accessing grafana directly (via NodePort) it worked.
As soon as I tried to use an ingress (reverse proxy) and add GF_SERVER_ROOT_URL I got the result you mentioned above.
When I had a look into the *.css and *.js resources which are getting loaded they do NOT contain CSS or JS code but the same HTML code from the initial HTML call.
That’s what I found in the logs (kubectl logs ):
Request Completed" logger=context userId=0 orgId=1 uname= method=GET path=/grafana/public/build/grafana.dark.css status=404 remote_addr=10.244.0.0 time_ms=250 size=12154 referer="http://kube-test.<replaced>.com:31928/?orgId=1
Lastly it was a misconfiguration of the ingress. Using traefik as ingress controller / reverseproxy I had to add
traefik.ingress.kubernetes.io/rule-type: PathPrefixStrip
to the ingress annotations. Previously I tried it with
traefik.ingress.kubernetes.io/rewrite-target: /
and that lead to the effect that the HTML was written in every other file.
Have fun
Greets
CCarpo
Hi
I have the same problem.
grafana_6.2.5_amd64.deb
nginx server with reverse proxy.
This is not loading the static file(css and js). The authentication is ok.
Example of ajax result:
How can i change the GF_SERVER_ROOT_URL in debian system?
I am having the same issue, deployed grafana in kubernetes. Any help?
Thank You!
