When i open my grafana page, suddenly is show this instead of my regular home page:
**If you're seeing this Grafana has failed to load its application files**
1. This could be caused by your reverse proxy settings.
2. If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true.
3. If you have a local dev build make sure you build frontend using: yarn start, or yarn build
4. Sometimes restarting grafana-server can help
5. Check if you are using a non-supported browser. For more information, refer to the list of [supported browsers](https://grafana.com/docs/grafana/latest/installation/requirements/#supported-web-browsers).
I know my browser is updated to the latest version AND I have tried chrome, firefox and edge.
I have not touched anything in my grafana.ini file that could have anything to do with it.
does somebody know a solution?
