Hi, i have AWS CloudWatch as Datasource.
Im trying to make a dashboard with some date data.
My query returns this info:
I just want to remove the hour + min + secs time stamps, i only need the YYYY-MM-DD
Im using Grafana 8.0.6
Thanks in advance
Thanks in advance
I’m also having this same problem.
Presume you’re using API Get and the result is JSON?
I’ll let you know I get anywhere!
Hello, maybe it’s too late but I have the answer.
This is my input before all transformation :
But I don’t want this format, so, I go “Transform”, then “Convert field type”
The result is :
But now, I want to erase the “000” like your problem.
So now I go on right panel and click on “Add Field Override”
And I manually add this : time: YYYY-MM-DD hh:mm:ss (copy paste)
(time: YYYY-MM-DD in your case)
So now I have this result :
So now I have the good format and I delete the “000”
See you.
