Change time format
Hi can someone help me change time format
I want to leave just date without 00:00 time
Welcome @goofas7
Try an override like this:
Before:
Create override and click on what you just entered:
short video here: Date in table column in Grafana dashboard instead of date and time - #7 by grant2
After:
same result
@goofas7
When you entered the custom unit in the override, did you click on it (like in the short video shows)? When you do, the word “time: YYYY-MM-DD” should appear.
dont know why but after restart everything is ok. thx
