Reinstall grafana
I had a grafana on a pi but the SD card was broken, hopefully i have a backup of the sd card.
I will reinstall grafana on a new SD card, is it possible to get the dashboard from the SD back up ?
Is it a file somwhere i can just copy/past ?
Grafana uses an embedded Sqlite database for storing all the data - like dashboards and users. If
you can find the data/grafana.db file in your backup files, then you can copy that over to the same location on your new SD and start the grafana service.
To back up Grafana, you only need to save the grafana.db file.
Also, upgrade instructions - might be useful: https://grafana.com/docs/grafana/latest/installation/upgrading/
