I don’t have access to grafana gui and now need to get backup from all dashboards that I have created and import them in new grafana server . How can do it ?
what database backend does the grafana server use
why do you no longer have access to the gui?
It is using default database sqlite3 . actually I just copy a plugin in /var/lib/grafana/plugin and after that could not restart grafana so grafana cannot start . Also I removed that plugin but the issue exist . So I want just migrate my dashboards to new grafana server
that would be using a sledge hammer to drive a needle ![]()
What does your log file say? What plugin did you install and how did you install it?
But if you just want to bring it back up
Install same version somewhere else
Copy the data and conf folder to this new install
restart this new server
Actually I installed the same version of grafana on the other system and just copy grafana.db (/var/lib/grafana/grafana.db) to new server but grafana service could not start . Also I hav einstalled enterprise grafana without license
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:10.66+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:10.66+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-01-23T20:07:10.66+0330 lvl=eror msg="alert migration failure: could not get migration log" error="failed to check table existence: unable to open database file: permission denied"
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:10.9+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:10.9+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-01-23T20:07:10.9+0330 lvl=eror msg="alert migration failure: could not get migration log" error="failed to check table existence: unable to open database file: permission denied"
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:11.16+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:11.16+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-01-23T20:07:11.16+0330 lvl=eror msg="alert migration failure: could not get migration log" error="failed to check table existence: unable to open database file: permission denied"
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:11.41+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:11.41+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-01-23T20:07:11.41+0330 lvl=eror msg="alert migration failure: could not get migration log" error="failed to check table existence: unable to open database file: permission denied"
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:37.99+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:37.99+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:38.41+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:38.41+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:38.66+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:38.66+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:38.91+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:38.91+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:07:39.17+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:07:39.17+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Starting Grafana" version= commit= branch= compiled=1970-01-01T03:30:00+03:30
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="The state of unified alerting is still not defined. The decision will be made during as we run the database migrations"
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:00.3+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:00.3+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-01-23T20:38:00.31+0330 lvl=info msg="Starting DB migrations"
logger=migrator t=2023-01-23T20:38:00.32+0330 lvl=info msg="Executing migration" id="clear migration entry \"remove unified alerting data\""
logger=migrator t=2023-01-23T20:38:00.32+0330 lvl=info msg="Executing migration" id="move dashboard alerts to unified alerting"
logger=migrator t=2023-01-23T20:38:00.32+0330 lvl=info msg="alerts found to migrate" alerts=0
logger=migrator t=2023-01-23T20:38:00.32+0330 lvl=info msg="Executing migration" id="clone move dashboard alerts to unified alerting"
logger=migrator t=2023-01-23T20:38:00.33+0330 lvl=info msg="Executing migration" id="update dashboard_uid and panel_id from existing annotations"
logger=migrator t=2023-01-23T20:38:00.33+0330 lvl=info msg="migrations completed" performed=4 skipped=392 duration=9.390527ms
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:30.35+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:30.35+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:30.66+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:30.66+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:30.91+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:30.91+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:31.17+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:31.17+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:31.41+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:31.41+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:55.07+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:55.07+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:55.41+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:55.41+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-23T20:38:55.66+0330 lvl=info msg="App mode production"
logger=sqlstore t=2023-01-23T20:38:55.66+0330 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2023-01-23T20:38:55.91+0330 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T23:20:28+04:30
logger=settings t=2023-01-23T20:38:55.91+0330 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
This is grafana.log file
