Grafana version 10.1.2
Deploying Grafana via helm chart version 6.60.1 -
The explore tabs range by default is 6 hours, I would like to make it 2 hours. I was not able to find what configuration change would update this, would someone point me to right place.
That is constant hard coded in the source code. It’s not configurable.
Got it. Thank you for the link.
