Hey guys, I connected Grafana with InfluxDB created dashboards and everything worked pretty smooth but after restarting the server and launching grafana again, All data disappeared, however after zooming, data is back. So If i set time range for 1h, I see nothing, Query inspector also gives no response, but if I zoom exactly one hour manually, all data is back and i can see proper response. What can be an issue?
EDIT
The problem seems to be solved, the issue was that after restart of server, date was changed to 2061 year. So timestamp generated by server was at this year and that was probably the reason why grafana didn’t want to display data correctly
