How to configure time range in dashboard
    I am using managed grafana
    If I mention some specific time range in my dashboard ,it does not show as per my configured time range
    example: If I mention like 30-06-2024 to 02-07-2024
    but my dashboard does not shows the result as per my condition
    Need to sort out that issue.Can you please tell if I made any mistake in that?
Hey @priyankag
What’s your datasource? What happen on the dashboard when you change the time range (nothing?)? Can you give us an example of one of your panel?
First of all Thanks for reply @codi639
My data source is “Time stream” and it is a streaming data .If I configure some particular time ,it does not show as per my data range ,instead of showing data as per my data range ,it shows different
Here, I mentioned only to get 6 hours ago data right,but what I am actually getting is data from 17th date . Why it is?What the things needs to be done for this ?
I’m not very used to Time stream, but I can still make some guess.
Please check that you actually have data that are from the past 6 hours.
Also, it could be an issue with the query, can you share it?
SELECT
t1.time,
t1.measure_value::double AS H2_Value,
t2.measure_value::double AS O2_Value,
(t1.measure_value::double / (t1.measure_value::double + t2.measure_value::double)) * 100 AS H2_Percentage
FROM
“new-trace-sensors-data”.“sensors_data” AS t1
JOIN
“new-trace-sensors-data”.“sensors_data” AS t2
ON
t1.time = t2.time
WHERE
t1.measure_name = ‘GS-AT-012’ AND t2.measure_name = ‘GS-AT-022’
This is the query that I have written for this visual
I have data for past 6 hours.But still it shows like this
I think I guessed right: the issue might come from your query.
In your query you are not using a timerange in your WHERE clause. As I said, I’m not very used with Time stream, but you can try to add the variable $timeFilter in your WHERE clause.
doc here
yeah sure ,Thank you so much @codi639
