Timepicker is not working well to my table
  • What Grafana version and what operating system are you using? Cloud
  • What are you trying to achieve? Trying to show data from AWS Timestream
  • How are you trying to achieve it? Grafana + AWS Timestream
I use this query
SELECT
device_id,
SUM(case when measure_name = ‘ntu’ then measure_value::double end) as ntu,
SUM(case when measure_name = ‘shutterspeed’ then measure_value::bigint end) as shutterspeed,
SUM(case when measure_name = ‘intensity’ then measure_value::double end) as intensity,
time
FROM $__database.$__table
group by device_id, time
order by time DESC
  • What happened? I made a table. Howerver I cannot apply time range from Grafana
  • What did you expect to happen? I would like to get data by using time range
welcome to the :grafana: community @jaeseolee!
To get your query to use the dashboard time range, you’ll want to use the $__timeFilter macro. The full example is available here in the plugin docs
SELECT
    silo, microservice_name, instance_name,
    CREATE_TIME_SERIES(time, measure_value::double) AS gc_pause
WHERE $__timeFilter
    AND measure_name = '$__measure'
