Time Picker not working for: geomap, table
I have a dashboard with a couple of geomaps and a table. I want the time picked from the time picker to also change what you view in my geomaps and my table.
I found some variable that could help, but I get an error if I use this method.
SELECT
  CAST("Longitude" AS DOUBLE) AS lon,
  CAST("Latitude" AS DOUBLE) AS lat,
  CAST("Direction" AS INT) AS direction,
  CAST("Speed" AS INT) AS speed
FROM ${database}.${table}
WHERE "Filter" = 'mon' AND $__timeFilter(time)
ORDER BY time DESC
LIMIT 10
I am using AWS Timestream datasource in Grafana.
ValidationException: The query syntax is invalid at line 7:110
Somebody know a solution?
got it, simple solution:
SELECT
  CAST("Speed" AS INT) AS speed,
WHERE
ORDER BY time DESC
LIMIT 10
