Dashboad datetime picker issues with mysql DB
    Version 11.2.0
    Create a dashboard with time series chart and user able to pick a datetime range from the dashboard
    Using global var like $__Timefrom() & $__Timeto() in the query
  • What happened?
  1. line chart did not display but table view with data available. (where Dt_STAMP between $__timeFrom() and $__timeTo())
  2. Using constant datetime in query, it is able to work (where Dt_STAMP between ‘2024-09-09 01:00:00’ and ‘2024-09-09 02:30:00’ )
    the query execute with the datetime selected by user in the datetime picker. Like a dynamic variable.
are you including the timestamp in your query, not just filtering on it?
can you share you sql statement?
Hi sowdenraymond,
Thanks for your reply. Yes i did include timestamp in my query.
Here is the sql statement that having problem:
SELECT Dt_STAMP, TB, STN_NO, LOAD_FORCE_BOTTOM, LOAD_FORCE_TOP
FROM tableau.TB_KPI
WHERE Dt_STAMP between $__timeFrom() and $__timeTo()
AND TB_Type = ${tb_type:sqlstring}
AND TB = ${tb_machine:sqlstring}
AND STN_NO = ${station_no:sqlstring};
can you share the value of Dt_STAMP?
Hi, Here is how Dt_STAMP look like.–> “2024-09-10 09:00:17”
Below is the print screen.
