v8.0.1 (8849243d27)
For my panel on Dashboard I use the following query to load data from my SQL db table:
SELECT sum(value)
FROM my_table
WHERE $__timeFilter(datetime_column)
It loads data for the chosen time range. I would like to load data for the time range larger than the chosen one. More specifically I would like to move the left side of the range, e.g., $__from - 10 min
- How are you trying to achieve it?
SELECT sum(value)
FROM my_table
WHERE datetime_column BETWEEN $__from - 10M AND $__to
and also
WHERE datetime_column BETWEEN DATE_ADD($__from, INTERVAL -10 MINUTE) AND $__to
What happened?
Error -
For the chosen time range the data loaded for the range a bit larger than the requested one and calculated SUM (this is only one example). -
SELECT sum(value)
FROM my_table
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
db query error: mssql: Operand type clash: datetimeoffset is incompatible with numeric
- Did you follow any online instructions? If so, what is the URL?
Add variables | Grafana documentation
