Add the time range variable to (postgresql) query (in the panel)
    I am using Grafana * v9.3.6 on Windows 10.
    I aim to display the count of certain records using a panel visualization. I successfully ran the PostgreSQL query to fetch the count of the records. I have to now apply a specific type of time range filter to the query to allow the user to filter records during whichever time period they wish to choose.
    The PostgreSQL query worked for a hardcoded time range, I have pasted the specific line of my query:
    between (ā€˜01-Jan-2023’) and (ā€˜15-Feb-2023’)
I now want to extract the time selected by the user and place it instead of the hardcoded data values(which I guess will be done using global variables ${__from} and ${__from}.
to achieve the specific date format, I altered the query as:
between ā€˜${__from:date:DD-MMM-YYY}’ and ā€˜${__to:date:DD-MMM-YYY}’
  • What happened?
    However the results that were displayed for the hardcoded values are not visible now. I was using a gauge visualisation and the numerical values I could see before are now all set to 0. There is no error. Just the number 0 is displayed.
    I expected it to display the same values as before (when I used the hardcoded date)
No errors received.
@saymeowmeow in your hardcoded example, it looks like your date is in format DD-MMM-YYYY, but your variable shows only 'YYY`.
Depending on what your data looks like, you might also check out these supported date macros for the postgres datasource:
Thank you! It was resolved when I used the following variable format in my postgreSQL query:
BETWEEN ā€˜${__from:date:YYYY-MM-DD}’ and ā€˜${__to:date:YYYY-MM-DD}’
I just had to correctly match it to the date time format in my table
