Hi, I am stuck with this problem on grafana,
actually Grafana v10.2.2 running on docker and well shows graph by flux,
I would try to add a Data source : a file .csv.
the file is provided by a link like: http://192.168.xxx.xxx:PPPP/share.cgi?ssid=somethingoforiginalhere
and grafana page tell me a “Success” (!)
But even the file is simple as possible I got only :
Record on line 5: wrong number of fields
I cannot see the raw table itself, no data, no graph.
Is it a generic error ? It persist even changing the file.
Thank your for thre reply !
Yes, the file was in that format I tried also
variable_1,variable_2
1,2
3,4
BUT I solved:
the link set in grafana is a link that open a webpage where the user can click to download the file.
I discover later this, “SUCCESS” for grafana is almost reading a file, not parsing it. (this will be done later)
Anyway : I will remember to CHECK the link : it must be a direct url to a file not to a dinamic page.
