Csv querying problem
Dear,
I am completely new to grafana. I would like to use as a data source in Grafana Cloud a .csv file, that is in a public github folder here: https://github.com/claudiocarnevale/prova_dati/blob/main/asseX_40.csv
I added the csv plugin by Marcus Olsson and then I data the csv data source:
I tried to explore the data, in particular the latitute column, but I find this problem:
I made some mistake, but I really do not understand :frowning: .
Claudio
PS: in the url in configuration page, I put the whole address: https://github.com/claudiocarnevale/prova_dati/blob/main/asseX_40.csv
and in the path in the explorer tab I do not put anytthing…
Thank you!
I could have paid more attention!
Thanks for your time!
Cla
you need to quit decaf! or time for another coffee break!
