Image - grafana/grafana:9.0.0
Chart - 6.31.0 -
Azure cost and log analytics dashboards across 50+ dashboards with access from 10+ users. -
We have installed Grafana onto an AKS cluster and have configured two types of Datasources: AzurePlus and AzureMonitor. Both of these have been set up with separate App Registrations and then split by each subscription we have.- The AzurePlus Datasource has been created via the datasources.yaml in our helm values
- The AzureMonitor Datasources have been manually created as Datasources
What happened?
Both of these Datasources work successfully, however, after slightly heavier usage (more than 1 user), we see:- The AzurePlus Datasource gives us 429 errors
- The AzureMonitor Datasource times out after 30 seconds and returns us a 400
We want to be able to support multiple users and alerts contacting our Azure tenant without failed requests. -
The below diagram describes our setup and the errors we are seeing:
Azure Monitor data source | Grafana documentation
429 - you are firing too many requests against Azure API.
So decrease them, e. g. don’t refresh dashboards, so often, don’t run alert rules so often,…
Thanks for responding! ![]()
Sure, I understand that for the AzurePlus data source, however, for the query API that is used by the AzureMonitor data source, I don’t believe we’re hitting the documented service limits:
And we’re also getting a 400 Invalid Request response following a 30-second timeout rather than a 429, when just prior to refreshing the dashboard once, I can see a workspace request being made with the following response header:
X-Ms-Ratelimit-Remaining-Subscription-Reads: 11994
is there a way I confirm what is happening with these requests being made via the AzureMonitor Datasource in more detail?
I don’t know. Try standard approach: usw debug log level and check a Grafana server logs.
Did you end up finding a solution or workaround for this problem? I’m running into a very similar issue with Azure Monitor API limits and multiple dashboards/alerts and I’d really appreciate any insight you could share.
Thanks in advance!
