Hi everyone,
First post on this topic. I hope the information is detailed enough
Grafana 8.2.2 on Ubuntu 18.04.6 LTS. Installed through apt-get. Grafana 8 alerts are enabled. Configured Azure Monitor datasource. Confirmed working (I can use the datasource in a dashboard) -
I’m trying to create a new Grafana Managed alert via Alert Rules → New Alert Rule -
- Rule name: ‘Test’
- Rule type: Grafana managed alert
- query A
– datasource: Azure Monitor
– time range: now-10m to now
– Service: Logs
– Resource:
– query:
Perf
| where $__timeFilter(TimeGenerated)
| where CounterName == “% Processor Time”
| summarize avg(CounterValue) by bin(TimeGenerated, 5m), Computer
| order by TimeGenerated asc
(This is the exact same query as used in the dasboard. In the dasboard it works)
What happened?
As soon as the Azure Monitor datasource is selected in the query step above, an error pop up. -
I expected to see the exact same table as in the dashboard -
See the How step -
‘Error’ ‘Failed to evaluate queries and expressions: failed to execute conditions: failed to execute query A: no handler found for query type ‘’’ -
Unfortunately, couldn’t find any
