I’ve noticed that when I run a query in Grafana using the built in grafana-azure-monitor-datasource plugin, a query takes will take about 5 times longer than if I copy the exact same query out of Grafana (using Inspect > Query) and into the Azure Portal (Web UI) targeting my Log Analytics Workspace.
This is true for both simple/narrow and complex/big queries. It’s particularly a problem with big queries because they time out in Grafana (but run fine in Azure Portal).
Is this the expected & normal behavior or does it indicate some configuration problem on our end? In other words, does Azure apply some deprioritization or rate limiting to external queries that they don’t to things running from within the Portal?
- Azure Managed Grafana
- Pro (Licensed)
- v9.0.8.1 (2ab85989b8)
Trying to make Azure queries run at a similar speed as they do in the Azure Portal. -
Comparing the Total request time for the same query between Grafana and Azure Portal -
What happened?
Grafana is about 5x slower than Azure Portal across many tested queries. -
I would hope for similar response times from Azure as they provide in their WebUI -
N/A -
No errors other than timeouts if our query takes too long from Grafana. -
N/A
