I have some dashboard that have at least 20 widgets.
All widgets executing different queries, using Azure Monitor plugin (one plugin for all of the widgets), against Log Analytics. Some of them heavier than others.
My questions…
- Is there a way to trace the response time of each query? (from Grafana)
- Some time it take about 1 min or more to load the dashboard, and see “Fetching…” or “Services…” in progress. Is there a way to understand why it take so long time? (what Grafana executing in back ground.)
Note: I have 2 variables that also executing a query, to be able to filter widgets using drop down. - Is there any configuration that I can change\adapt to increase or decrease number of thread the plugin executes or number of user can connect to Grafana at same time?
- Is there any suggestion how I can influence on performance\response?
