I am adding 2 fields together and when I am in editor mode in SQL everything is fine and my chart or table is working as expected.
When I change back to GUI editor ( visual SQL ) and try and change time range I receive a parse query error and if I go back to inline mode I see that an extra “comma” has been inserted.
I would prefer to do the SQL query in the front end editor but it doesn’t seem to allow the simple + ( its actually kind of confusing how it adds a new query parameter on a new line ( I guess that’s why there is a comma in the SQL ) … Is there a way to overcome my issue of the front end and inline editor not synching correctly with each other? is this a bug or know issue ? how can I save the correct SQL ? any help .
ps. ( I have no idea why I need insert (mean) before each value for it to work either - I’m really just wanting field A + field B ( without the confusing maths +100 ) …
